Apache2.2 и 1С 8.2 - нестабильная работа.
0 RedTop
11.05.12
05:33
База опубликованна через Apache.
Переодически в логах появляется следующее:
[Fri May 11 11:28:39 2012] [notice] Apache/2.2.22 (Win32) configured -- resuming normal operations
[Fri May 11 11:28:39 2012] [notice] Server built: Jan 28 2012 11:16:39
[Fri May 11 11:28:39 2012] [notice] Parent: Created child process 5464
[Fri May 11 11:28:39 2012] [notice] Child 5464: Child process is running
[Fri May 11 11:28:39 2012] [notice] Child 5464: Acquired the start mutex.
[Fri May 11 11:28:39 2012] [notice] Child 5464: Starting 64 worker threads.
[Fri May 11 11:28:39 2012] [notice] Child 5464: Starting thread to listen on port 80.
[Fri May 11 11:59:34 2012] [notice] Parent: child process exited with status 1 -- Restarting.
[Fri May 11 11:59:34 2012] [notice] Apache/2.2.22 (Win32) configured -- resuming normal operations
[Fri May 11 11:59:34 2012] [notice] Server built: Jan 28 2012 11:16:39
[Fri May 11 11:59:34 2012] [notice] Parent: Created child process 6128
[Fri May 11 11:59:34 2012] [notice] Child 6128: Child process is running
[Fri May 11 11:59:34 2012] [notice] Child 6128: Acquired the start mutex.
[Fri May 11 11:59:34 2012] [notice] Child 6128: Starting 64 worker threads.
[Fri May 11 11:59:34 2012] [notice] Child 6128: Starting thread to listen on port 80.
[Fri May 11 11:59:42 2012] [notice] Parent: child process exited with status 1 -- Restarting.
[Fri May 11 11:59:42 2012] [notice] Apache/2.2.22 (Win32) configured -- resuming normal operations
[Fri May 11 11:59:42 2012] [notice] Server built: Jan 28 2012 11:16:39
[Fri May 11 11:59:42 2012] [notice] Parent: Created child process 9076
[Fri May 11 11:59:42 2012] [notice] Child 9076: Child process is running
[Fri May 11 11:59:42 2012] [notice] Child 9076: Acquired the start mutex.
[Fri May 11 11:59:42 2012] [notice] Child 9076: Starting 64 worker threads.
[Fri May 11 11:59:42 2012] [notice] Child 9076: Starting thread to listen on port 80.
подскажите, что может вызывать такие рестарты?
1 RedTop
11.05.12
Все крутится на Windows 2003 R2 64bit
2 gavrikprog
11.05.12
технологический журнал запускай - тебе никто ничего не скажет.
У меня тоже падало, но юзверей много было - я загнал всех в терминал.
То есть не решал вопрос. Ибо решил на скуль все повешать в локалке чуть попозжа.
3 RedTop
11.05.12
я так понимаю у IIS таких проблем нету и он ровнее работает с Апачем?
4 RedTop
11.05.12
IIS ровнее работает с 1С 8.2*
5 RedTop
11.05.12
попробовал перекинуть на другой порт 8080, для этого в конфиге httpd.conf переделал строки:
Listen 192.168.0.101:8080
ServerName 192.168.0.101:8080
1с вообще перестала работать через Web
6 RedTop
11.05.12
как перекинуть работу 1с через апач на другой, отличный от 80 порт? или 1с жестко завязанна на него?
